14 years agoCyclone IV GX dev kit HSMC connection buned MAXII BGA chip
Hi all, I have a serious question here. Please spend some time to read through my explanation below as I really need some help! I appreciate your time very much. Previously I used the Cycl...
14 years ago --- Quote Start --- From the C4GX DevKit Reference Manual, table 2-8 Board-Specific LEDs: "D1 PSNTN A Green LED. Illuminates when the HSMC port A has a board or cable plugged-in such that pin 160 becomes grounded. Driven by the add-in card." So your daughter board should connect the PSNTn pin directly to the GND. --- Quote End --- I see.. I appreciate very much. I think this might be one of the possible reason of why the MAXII burned. Because at the daughter card, I am actually supplying voltage to the HSMA_PSNTn line into C4GX dev kit. However, since this HSMA_PSTNn also connecting to C4GX FPGA, I affraid the FPGA might have already burned as well. I need to check on that. By the way, what is the function of EPCS128 used for? Because I detected that my voltage supply of 3.3V from LTC3850 is shorted and I identified that EPCS uses 3.3V supply. I affraid this IC is damaged too. May I know what's the function of this IC? thank you. Thank you again.
