18 years agoCyclone III/HSMC pin voltage
I have a Cyclone III starter kit with the Bitec HSMC breakout adapter, and I need to interface with some 3.3V devices through the adapter pins. It seems that even changing the pin voltage in th...
18 years agoHello,
I don't know about the details of the said hardware, but I/O voltage is primarly a hardware feature, defined by supplying the respective VCCIO with either 2.5 or 3.3 V. IO-standard should be set according to VCCIO but can't change the pin voltage. Regards, Frank
