18 years agoCyclone III Starter Kit - JTAG programming
Has anyone been able to program (i.e. download a design) using the JTAG interface located in J4? The USB blaster interface seems to be working just fine, but when I populated the J4 connector I get a...
18 years ago --- Quote Start --- You didn't tell what adapter you connected when trying to program through J4. An USB Blaster? --- Quote End --- Ya, I am using USB blaster Rev C and try to access the J4 with the JP8 had already been shunted. It seems like this port is working with the board that labeled 6xx-4133R-0D, but failed with 6xx-4133R-0B. This label can be viewed on the bottom of the board. The sticker of 6xx-4133R-0D is covering the original board printing 6xx-4133R-0B, as 0D's board comes with the extra 10pin male header, while 0B's board doesn't and one must solder the pins by himself. I think this is a hardware bug. :mad:
