16 years agoCyclone III Starter Kit - DDR-SDRAM - help
I'm newbie user in FPGA and I need to read and to write in DDR-SDRAM from Cyclone III starter kit. I altered the QB3 example (.bdf). And I created a new project in Nios II loading the .ptf f...
16 years agoMy really question is:
I want to write and to read in ddr-sdram. I have four options: *Implement all logic by "hand" (in code VHDL); *Use the SOPC Builder for start the project from 'zero'; *Change the QB3 Control Painel example; *Change the CycloneIII_3c25_start_niosII_standard example. Changing the QB3 Control Painel example, I don't have the SOPC Builder System PTF file for implement my code in Nios II. And I don't get to create this file. Changing the CycloneIII_3c25_start_niosII_standard example, my project have only: Nios II processor,DDR-SDRAM controller,jtag,onchip memory and led pio. I compile the project, and in the Nios software, I program this code: int main(void) { int ch; int a,b,c,d; int memory_base = 0x02000000; /* Print the Header */ MenuHeader(); /* Print the menu and do what the user requests, until they hit 'q' */ while (1) { IOWR_8DIRECT(memory_base, 0, 0x0A); IOWR_8DIRECT(memory_base, 1, 0x05); IOWR_8DIRECT(memory_base, 2, 0xA0); IOWR_8DIRECT(memory_base, 3, 0x50); a = IORD_8DIRECT(memory_base, 0); b = IORD_8DIRECT(memory_base, 1); c = IORD_8DIRECT(memory_base, 2); d = IORD_8DIRECT(memory_base, 3); printf( "\nmemory 1 = %d.\n",a); printf( "\nmemory 2 = %d.\n",b); printf( "\nmemory 3 = %d.\n",c); printf( "\nmemory 4 = %d.\n",d); //ch = TopMenu(); if (ch == 'q') { printf( "\nExiting from Memory Test.\n"); break; } } return (0); } But, when I run this, appears a error: Verifying 02000000 ( 0%) Verifying 02010000 (83%) Verifying 04001020 (99%) Verify failed between address 0x4001020 and 0x40011C7 Leaving target processor paused Someone help me ? Before tihe, I tried to test the memory test template of Nios II and I don't have success too.
