16 years agoCyclone III Starter Board - Using the DDR-SDRAM
Hi, I have a Cyclone III Starter Board and I already made the myfirstfpga-tutorial (http://www.alteraforum.com/forum/www.altera.com/literature/tt/tt_my_first_fpga.pdf). So I understand the bas...
16 years agoSo have you done write and read DDR-SDRAM successfully? can we have more details on how to do that?
Thank you very much! --- Quote Start --- Now I have found the solution: Open the qb3_control_panel example project and use signaltap to find out which pin is for what. Then it becomes very easy. --- Quote End ---
