16 years agoCyclone III Starter Board - Using the DDR-SDRAM
Hi, I have a Cyclone III Starter Board and I already made the myfirstfpga-tutorial (http://www.alteraforum.com/forum/www.altera.com/literature/tt/tt_my_first_fpga.pdf). So I understand the bas...
16 years agoYour best bet is to take the exact device partnumber and look up the datasheet on the web. Micron for example explains in great detail how their SD-RAMs work, how to operate them and so on and so on. Step 1 is to learn to understand the device.
I did the same for the ISSI SRAM on the board (much simpeler than DDR SDRAM but the process is the same) and wrote a controller around it after I understood exactly how the SRAM works.
