16 years agoCyclone III Starter Board - DDR_CNTR, license problem
Hello, I have a Cyclone III Starter Board and I wanted to use the sample project called “qb3_control_panel”, which is on the CD that comes with the board and gets installed with cycloneiii_sta...
16 years agoNow I have the solution! Never thought I'd manage to solve the problem on my own...
So here is how to use two different License Files: In Windows Vista, you have to create a "environment variable" called lm_license_file. The value of this variable must contain the path to your two license files or servers, separated by a semicolon. For example:
1234@server; C:\path\license.dat
In the attached image you can see where to make that setting in Windows Vista (unfortunately I only got the German Version of Vista). Then it should work...
