16 years agoCyclone III Starter Board - DDR_CNTR, license problem
Hello, I have a Cyclone III Starter Board and I wanted to use the sample project called “qb3_control_panel”, which is on the CD that comes with the board and gets installed with cycloneiii_sta...
16 years ago --- Quote Start --- What quartus version are you using? --- Quote End --- I am using Quartus version 8.0. But I could also get the 9.0 version. --- Quote Start --- For me the license file works under 8 and 9. I do notice that you have a slightly older starter kit as indicated by its version 7.1. Mine is 7.2. --- Quote End --- Maybe you have a different License file. Can we compare our license files? --- Quote Start --- I'm afraid I can't help you further - I can't find any other license files in the starter kit directories. --- Quote End --- Are you using the 30 day trial edition of Quartus? Is there a possibility to have two different license files? The problem is:
- When I use my Quartus network license (Full Version), I can't use the DDR_CNTR function of the starter kit.
- When I enter the license file of the starter kit (in license setup), Quartus doesn't run at all (see my previous post)...
