16 years agoCyclone III Starter Board - DDR_CNTR, license problem
Hello, I have a Cyclone III Starter Board and I wanted to use the sample project called “qb3_control_panel”, which is on the CD that comes with the board and gets installed with cycloneiii_sta...
16 years agoHi MagicBox,
Thanks for your reply! But it still doesn't work: I have selected now the following license file: c:\altera\kits\cycloneiii_starter_kit-v7.1.0\examples\ciii_control_panel\license.dat When I compile it, I get the following error message:
Error: Specified license does not contain information required to run the Quartus II software
And when I close and restart Quartus, it seems that the license file is not valid at all (for my copy of Quartus), because I get asked again for a valid license (see the first attached picture). I am confused a little bit because I thought I had a full version (see my first post)... You can see in the second attached picture which licensed functions I have with my normal network-license. With the new license.dat it shows the following in the license setup:
License Type: No License
Subscription Expiration: Not found
Host ID Type: Not found
Host ID Value: Not found
As I have a network license (for up to 5 PCs), I don't want to begin a 30-day Evaluation Period... What can I do if I want to use Quartus II with my Full License and also use the DDR-Controller which comes with the Cyclone III Starter Board? Kind regards, stefan__
