17 years agoCyclone III Starter Board - CFI programming
Hi, I tried to program the Intel P30 flash device following the instructions of the Cyclone III FPGA Starter Kit User Guide in Appendix A but the Quartus II Programmer shows three errors and th...
15 years ago --- Quote Start --- u must vonvert .sof to .pof and baseaddress=0x20000 then use quartus programmer to burn ,in programmer you can select auto detect then attach flash device then change file to select your .pof then check program/config top line auto select to default pfl then press start,ok.if you have nios in flash programmer you do not check Program FPGA configuration. --- Quote End --- Hello, Can you please explain more your procedure to program flash memory with a Nios core processor.
