18 years agoCyclone III, Nios II evaluation KIt & analog video
Hi all, I'm planning to connect an analog camera (PAL/NTSC) to the composite video input. I know the capabilities of ALTERA above video&image processing. I'm thinking of use Deinterlacer, chrom...
17 years agoI've checked video application using my cyclone II evaluation kit, using a project verilog based downloaded from the TERASIC web page.
You must keep in mind that this application only works for NTSC analog video input, but not using PAL video. In this case you should change some parameters
