18 years agoCyclone III, Nios II evaluation KIt & analog video
Hi all, I'm planning to connect an analog camera (PAL/NTSC) to the composite video input. I know the capabilities of ALTERA above video&image processing. I'm thinking of use Deinterlacer, chrom...
18 years agohi fvm,
first all, thanks a lot!!! your feedback as always is very appreciated. I'll examine this information!!!. I'm working in a project involving inspection by processing of thermal images using cameras based in infrared thermography . I've developped the main algorithm using Matlab and after I've ported the code to Simulink-DSP Builder in order to simulate the behaviour of its hardware implementation. I'm thinking of use Cyclone III embedded evaluation kit as main platform to work this algorithm, in order to doing that, I can connect an OEM camera using some of these interfaces, *Analog video input. Video decoder in this board has only 8 bit, I think it's a little poor. *video over LVDS. I can't see any conector for general purpose available in this board to be able to implement LVDS channels. *video over Ethernet. NIOS+Niche_stack+Phy+Opencore. Fast enough to 320x240x12bit x 30fps real time video capture??? Any suggestion will be appreciated. Thanks in advance
