16 years agoCYCLONE III esdk KIT multimedia lcd factory demo
I have just buy a Embedded system development Kit CYCLONE III and when I power on first time the visual test is: blue led power : on power display 7seg value: 1198 green leds [0-7]: on HSMB_PSNTN green led D19: on FACTORY D24 led: on CONF_DONE D25 led:on LCD MULTIMEDIA SCREEN : its OFF. Dont see Welcome Screen Message ¿Its some wrong? ¿there is some selector button or switch for up the brigthness? The kit its new and the first power on failed? i have do the instruccion manual for factory demo recovery and the result is the same -> Not screen Welcome THANKS IN ADVANCE1 Reply
I would like know how must i configure the board for factory setup I think that is SW3_FPGA_BYPASS=1=ON SW1_5=MAX0=OPEN=1=OFF -> FPGA programming from flash_memory PGM_CONFIG_SELECT=0 If i powerup with SDcard insert the application menu are on screen BUT If i powerup WITHOUT sdcard insert, THERE IS NOT THE WELCOME SCREEN thanks
