17 years agoCyclone III / Bitec Video Dev Kit
Hi I got the Cyclone III dev kit a few days ago together with the Bitec dvi in/out and the quad comp board. First I tried to run the 71 vesion of Quartus II and Nios II on Vista ...no lu...
17 years agoThepancake
The Nios problem have to wait a bit... I can easy do some testing whan I use Quartus now I have realy tried to understand a way to do some rotating but I'm still stucked. The video goes to the FIFO which does hold 1 line of RGB then the DMA do transfer it to the RAM ....but I do not see a way to tell it to put data on every 640*X instead of a block (row) from the pointer I also didi think of making 2 counters and just read 1 byte at a time and put it where it need to go... but I belive thes will way to slow If you have more details it would be great Wiljan
