17 years agoCyclone III / Bitec Video Dev Kit
Hi I got the Cyclone III dev kit a few days ago together with the Bitec dvi in/out and the quad comp board. First I tried to run the 71 vesion of Quartus II and Nios II on Vista ...no lu...
17 years agoHi
thepancake thank you for feedback here you have the error log from Quatrus II 8.1 on my Vista PC I would realy hope I can work on this PC since it's quad core and pretty fast compared to my XP laptop Error: wrong# args: should be "post_sdc_message msg_type msg" while executing "post_sdc_message -type critical_warning "Could not find correct number of DQ pins for DQS pin $i. Found [llength $dq_p] pins. Expecting 8." " (procedure "get_ddr_pins" line 15) invoked from within "get_ddr_pins $instname pins" (procedure "add_requirements_for_instance" line 16) invoked from within "add_requirements_for_instance $corename $inst t $ddr2_32bit_phy_use_high_performance_timing" ("foreach" body line 3) invoked from within "foreach inst $instance_list { post_sdc_message info "Adding SDC requirements for $corename instance $inst" add_requirements_for_instance $corename $..." (file "ddr2_32bit_phy_ddr_timing.sdc" line 365) Error: Can't fit design in device Error: Quartus II Fitter was unsuccessful. 2 errors, 23 warnings Error: Peak virtual memory: 324 megabytes Error: Processing ended: Tue Jan 27 21:00:25 2009 Error: Elapsed time: 00:00:14 Error: Total CPU time (on all processors): 00:00:14 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 248 warnings If you like you can try yourself ... grab the code here http://www.bitec.ltd.uk/outgoing/bitec_hsmc_quad_video_28mar08.zip Best regards Wiljan
