17 years agoCyclone III / Bitec Video Dev Kit
Hi I got the Cyclone III dev kit a few days ago together with the Bitec dvi in/out and the quad comp board. First I tried to run the 71 vesion of Quartus II and Nios II on Vista ...no lu...
17 years agoHi
And now a bit more progress... I did install the Nios and Quartus II v 7.1 on my XP Nios part compiled fine as in 8.2 and now so did the Quartus part... After 1H 36M and it did compile without Error :) Now I did make a small change to the top evel design so I expected the video to all 3 hannels to come from input 1 Hit start compiling...... 1H36 minuttes later no error and I did download againg to the Cyclone III and loaded the soft from Nios... black screen :( It seems imposible to me to do develomping if I have to wait so long time after every change to see if it work or not So there must be some adjustment which make this compilation quicker... so the design are not optimized for picoSeconds.... any hint? Also I do still look for hints to rotate the video 90 deg Please let me know if you have ideas Wiljan
