17 years agoCyclone III / Bitec Video Dev Kit
Hi I got the Cyclone III dev kit a few days ago together with the Bitec dvi in/out and the quad comp board. First I tried to run the 71 vesion of Quartus II and Nios II on Vista ...no lu...
17 years agoHi
After a lot of different test I now have sample to work :) The real promlem was that I had to dowload the sof file before I right clik and say run as NIOS hardware ... then the verify error are gone... so far so good Now to what I really want to achieve I want to be able to run the Clyclone III with the Bitec DVI in / out for 1024x768@60 or higher The input video should be scaled down in size to like 25% and the been shown on the output DVI as 3 small windows (the rest are black) The window at the left should be rotated 90 deg CCW and the window to the right should be rotatec 90 deg CW and the one in the top should not be rotated Can someone recommend the best way to have this to work from some of the sample avaible? Or if you have other sugestions http://www.tech2net.dk/media/input.jpg http://www.tech2net.dk/media/output.jpg Best regards Wiljan
