16 years agoCyclone II EP2C35 - SOF downloaded but doesn't run
Hi, I am using Quartus II 8.0 with the nios ii development kit, cyclone ii edition (http://www.altera.com/products/devkits/altera/kit-nios-2c35.html). I created a very simple hardware design l...
16 years agoi don't think it is big difference that you use a c6 and can't select c8 in a working or non working image
but you wrote that the Conf Done LED is on for a few mSec. could it be that this board is reconfigured by a watchdoch or a fpga pin ? maybe you use a pin a bit different than the working sof i am unshure about the reconfiguration option due to an error that is avaiable in quartus settings.
