16 years agoCyclone II EP2C35 - SOF downloaded but doesn't run
Hi, I am using Quartus II 8.0 with the nios ii development kit, cyclone ii edition (http://www.altera.com/products/devkits/altera/kit-nios-2c35.html). I created a very simple hardware design l...
16 years ago --- Quote Start --- I understand that you are downloading just a Quartus program, without NIOS. --- Quote End --- That's right. --- Quote Start --- When you reset your Kit ... --- Quote End --- No, I did not press reset or turned power off. I programmed it, and when the progress bar in Quartus Programmer reached 100% some LEDs started blinking and the factory default image started. --- Quote Start --- I have the same Kit, I will try to check and help you. --- Quote End --- Thank you. :) --- Quote Start --- now he says the old image is used, so i assume that he downloads the old (already programmed) image. --- Quote End --- I don't think so. It's strange, because in the Quartus-project called "NiosII_cycloneII_2c35_standard" there is no problem, I can compile and download it and it runs. But my new project doesn't run. --- Quote Start --- do you have a web edition ? --- Quote End --- No, I have: quartus ii version 8.0 build 215 05/29/2008 sj full version Maybe there is a specific option / setting for this problem in Quartus ... ?
