15 years agoCyclone I development board
hello everybody!!
I am working on a project using an Altera cycloneI EP1C6T144C8. I would like to know what type of flash memory is compatible for this FPGA. Thanks!!2 Replies
--- Quote Start --- hello everybody!! I am working on a project using an Altera cycloneI EP1C6T144C8. I would like to know what type of flash memory is compatible for this FPGA. Thanks!! --- Quote End --- That would be EPCS1 (with compression) or EPCS4, EPCS16, EPCS64, EPCS128. Also the use of compatible devices from Numonyx, Micron, ST or Atmel or is possible (and cheaper). Good luck, Ton - Altera_Forum
thank you Ton :)))
