SATC
6 years agoCyclone 10 GX: The actual JTAG ID is different than was expected
The Quartus Prime Pro Edition 19.3 version has been used as IDE. I am trying to configure the CvP PCIe of Cyclone 10 GX according with this manual: https://www.intel.com/content/www/us/en/programm...
- 6 years ago
Thank you JohnT,
I unchecked the program/configure box with the .sof, thus the configuration was as follows the Figure.
In sequence, this error was presented to me: Error(209031): Device chain in Chain Description File does not match physical device chain -- expected 1 device(s) but found 2 device(s).
But, I found a similar case in this forum and I managed to solve the problem. The inclusion of a cdf file was enough to programmer the device.
JohnT_Altera
6 years agoHi,
I understand your concern but unfortunately there is no default chain that we can use as it will depending on board to board. So usually, user need to understand what is in the JTAG Chain so that the setting used is correct.
