SATC
6 years agoCyclone 10 GX: The actual JTAG ID is different than was expected
The Quartus Prime Pro Edition 19.3 version has been used as IDE. I am trying to configure the CvP PCIe of Cyclone 10 GX according with this manual: https://www.intel.com/content/www/us/en/programm...
- 6 years ago
Thank you JohnT,
I unchecked the program/configure box with the .sof, thus the configuration was as follows the Figure.
In sequence, this error was presented to me: Error(209031): Device chain in Chain Description File does not match physical device chain -- expected 1 device(s) but found 2 device(s).
But, I found a similar case in this forum and I managed to solve the problem. The inclusion of a cdf file was enough to programmer the device.
JohnT_Altera
6 years agoHi,
The JTAG ID code 0x031820DD is refering to the Max 10 (10M08) device. Could you try to performed auto-detect to make sure that you are using the correct JTAG chain?
