aamodini
1 year agoCyclone 10 GX Temperature Sensor - Memory Mapped Agent
Hi, I am trying to read out board temperature values using the Temperature Sensor IP, from Nios using the Avalon MM Interface. I am confused as to what the connections should be, since all t...
FakhrulA_altera
1 year agoHi Aamodini,
As mentioned by sstrell, the ADC does not natively support an Avalon interface. You can latch the data on tempout at the falling edge of eoc. When the corectl signal remains asserted, the ADC starts a new conversion cycle and provides an updated temperature value on tempout.
Let me know if you need further clarification.
Fakhrul
