OlegT's avatar
OlegT
4 years ago
Cyclone 10 GX FPGA Development Kit embedded Download Cable
Hello.
I am working with new Cyclone 10 GX FPGA Development Kit.
And I am not able to use embedded download cable.
When I plug USBA - microUSB cable to PC and power up the board, Windows 10 OS reports an error:
In device manager:
I've tried different PCs, different cables, but the result is the same.
+3.3V supply of CY68013 is ok, reset is High, oscillator runs 24 MHz.
If I plug external USB Blaster to J11 connector, I can successfully scan JTAG chan, C10GX can be successfully programmed.
How to solve this issue?
Oleg.
  • Looks like the problem lies in jtagserver.
    jtagconfig --serverinfo said, that server version was 19.1
    Then I run:
    1. jtagserver --uninstall
    2. cd to Q17.1 folder, where jtagserver resides.
    3. jtagserver --install
    Now jtagconfig --serverinfo says, that server version is 17.1
    And embedded cable recognizes:
    and works well.
  • OlegT's avatar
    OlegT
    I have an experience with CY7C68013 and I know, that it is a quite capricious thing.
    Could it be possible, that there is something wrong with MAX10 (U2), which is connected to usb controller?
    When I scan JTAG chain by external balster, this chip (U2) presents on the chain, but may be FW is wrong or missing?
  • OlegT's avatar
    OlegT
    Thank you, but no luck. The problem is still here.
    FYI:
    I have your old Lark Board. It aslo has embedded blaster, which is designed on CY7C68013. It works perfectly.
  • OlegT's avatar
    OlegT
    Then I run:
    and works well.
  • Hi,
    Thank you for sharing the solution with us.
