Cyclone 10 GX FPGA Development Kit - PCIe AvalonMM-DMA example
- 5 years ago
Hi Oleg,
Thanks for your patience while I was checking the design.
If you refer to the Platform Designer: Interconnect Requirements, there are some settings that allow the software to automatically insert the clock crossing adapters and add pipeline stages to the Platform Designer interconnect when you generate a system.
In our case, the clock crossing adapter type is set to FIFO and maximum pipeline stages is set to 4.
KhaiY
Hi Oleg,
The Clock Crossing Bridge allows pipelined read masters to post multiple reads to the bridge even if the slaves downstream from the bridge do not support pipelined transfers. Before using the clock crossing bridges in your design, you should
carefully consider their effects. The bridges can have any combination of the following effects on your design:
- Increased Latency - it has an effect on the read latency between the master and the slave.
- Limited Concurrency - Placing a bridge between multiple Avalon-MM master and slave ports limits the number of concurrent transfers your system can initiate.
- Address Space Translation - The slave port of a pipeline or clock crossing bridge has a base address and address span.
KhaiY
