manishkumar
2 years agoCyclone® V FPGA – Remote System Upgrade over UART Based on Nios® II Processors with EPCQ Design Exam
with given reference design example try to program the output_file.jic file through Quartus prime programmer as per the reference user manual in to the (Cyclone V E FPGA Development Kit) , but it is...
NurAiman_M_Intel
2 years agoHi,
- For confirmation, you are using Cyclone V E dev kit?
- What is the Quartus version that was used?
- You are using EPCQ flash?
- You are using USB Blaster 1 or II?.
- Make sure your MSEL setting is correct.
- Check the FPGA and flash connection.
- Try to check the connection of Intel FPGA Download Cable to header available on the board.
Refer the below link,
Aiman
manishkumar
2 years agoHi,
Confirmation for point no 2: Using Cyclone V E dev kit and as per schematic and BOM documents mentioned flash as EPCQ256. But in actual dev board kit mounted flash is of Micron 2WA15 RW164 . (attached picture for reference, Note: U2 is a Flash)
Can u plz confirm the part no of Flah device because it is a dev kit provided by Intel.
Kindly help to rectify the program flash issue
