manishkumar
2 years agoCyclone® V FPGA – Remote System Upgrade over UART Based on Nios® II Processors with EPCQ Design Exam
with given reference design example try to program the output_file.jic file through Quartus prime programmer as per the reference user manual in to the (Cyclone V E FPGA Development Kit) , but it is...
NurAiman_M_Intel
2 years agoHi,
- For confirmation, you are using Cyclone V E dev kit?
- What is the Quartus version that was used?
- You are using EPCQ flash?
- You are using USB Blaster 1 or II?.
- Make sure your MSEL setting is correct.
- Check the FPGA and flash connection.
- Try to check the connection of Intel FPGA Download Cable to header available on the board.
Refer the below link,
Aiman
manishkumar
2 years agoHi,
Answer to your queries:
1) using Cyclone V E dev kit
2) Quartus Prime lite edition 18.1
3) using EPCQ Flash (EPCQ256 mentioned in CycloneV E dev kit schematic and BOM)
4) using USB Blaster II connected to J10 connector of CycloneV dev kit
5) MSEL setting is MSEL{4:0} 10010 AS mode
6) using CycloneV E dev kit, so bydefault connection is present
7) properly connected and FPGA is detected on Quartus prime programmer (screenshot attached)
