Cyclone® V FPGA – Remote System Upgrade over UART Based on Nios® II Processors with EPCQ Design Exam
- For confirmation, you are using Cyclone V E dev kit?
- What is the Quartus version that was used?
- You are using EPCQ flash?
- You are using USB Blaster 1 or II?.
- Make sure your MSEL setting is correct.
- Check the FPGA and flash connection.
- Try to check the connection of Intel FPGA Download Cable to header available on the board.
Refer the below link,
Aiman
- manishkumar2 years ago
Answer to your queries:
1) using Cyclone V E dev kit
2) Quartus Prime lite edition 18.1
3) using EPCQ Flash (EPCQ256 mentioned in CycloneV E dev kit schematic and BOM)
4) using USB Blaster II connected to J10 connector of CycloneV dev kit
5) MSEL setting is MSEL{4:0} 10010 AS mode
6) using CycloneV E dev kit, so bydefault connection is present7) properly connected and FPGA is detected on Quartus prime programmer (screenshot attached)
Confirmation for point no 2: Using Cyclone V E dev kit and as per schematic and BOM documents mentioned flash as EPCQ256. But in actual dev board kit mounted flash is of Micron 2WA15 RW164 . (attached picture for reference, Note: U2 is a Flash)Can u plz confirm the part no of Flah device because it is a dev kit provided by Intel.
Kindly help to rectify the program flash issue
