Pochi
1 year agoCyclone® IV SDR SDRAM DDR2 Timing Parameter Settings
I found a document for DDR2 timing parameter settings, but I can't find anything for SDR. I would like to know the setting values of each parameter, so I would appreciate it if someone could help me....
AdzimZM_Altera
1 year agoHi Pochi,
I may not understand your question at this point. The setting is to define the memory characteristics.
So, it's limit to what memory has been used.
I don't think the FPGA has that information.
You may clarify your question if I'm not answering your question.
Besides, which IP that you are using and Quartus version?
Adzim
- Pochi1 year ago
Hi Adzim,
I was able to the information I wanted.
Pochi
