Cyclon III starter Kit, flash device
hello,
i have a problem to program the flash device of the cyclon III starter Kit. I use Quartus 7.2. Up to kno i program the *.sof file and the program works. Now i want to start the program, when i power-on my board. because of that, i do the steps, which are posted in the ug_ciii_starter_kit.pdf to program the flash device. when i finished the programming i switched off and on the board, but the progam didn't work. So i try to do it one more time, but then i get following error message: can't recognize silicon ID for device I. I have already read some posts in the forum and in the knowledge base, but i can't solve the problems. can somebody help me?????29 Replies
but in the reference manual, it is said, that the starter board has 8x16MB flash device, so cfi_128mb should be right. So i think that is not the problem
Try creating a flash test program and verify that you are able to read and write to each block of the cfi flash memory. I suppose you could use the memtest template from the Nios IDE. Just create a simple system in SOPC builder, compile it in Quartus II, download the sof file and verify whether you can read/write to each block of cfi flash memory or not.
Hope it will help. - Altera_Forum
Could any one please help me out at what frequency should i have to send the rgb values to the lcd , is it 25 MHZ or 75 MHz .. please let me know i will ver y thankful if you send me the verilog code - Altera_Forum
Is it possible to write in to flash using verilog code?
Yes, but there's no example with Terasic demonstration code, I think. Flash writes are handled in NIOS examples only. Writing to the flash implies some complex controller code, at least a state machine to time the enable sequences for flash programming. A FIFO may be useful for smooth operation.
I don't know about the CIII kit, but Terasic usually does provide a flash controller in Verilog. It is present in the Control Panel source code.
However Terasic demonstrations are usually too bad for learning purposes, they are barely commented if at all. Furthermore, the control panel doesn't attempt to be very efficient. E.g, most versions of the Terasic control panel doesn't let you erase individual sectors. It might be much better to use a CFI controller. It shouldn't be too difficult to find one, and I think that you get a clear source code (but of course, not commented) one when instantiating a CFI core in SOPC builder. - Altera_Forum
I have tried to generate code using SOPC Builder, but the code it has generated for flash is different from other devices.
For devices like SRAM and SDRAM, It has generated controller code, but for Flash it is not generating controller code, instead it has code which works itself as FLASH, code functions as flash (DUMMY FLASH). That code doesnt connect with hardware flash, but inside code it define memory array which saves data and work as flash memory. This is code generated by SOPC for FLASH ====>>main module is in the bottom // turn off superfluous verilog processor warnings // altera message_level Level1 // altera message_off 10034 10035 10036 10037 10230 10240 10030 module cfi_flash_0_lane0_module ( // inputs: data, rdaddress, rdclken, wraddress, wrclock, wren, // outputs: q ) ; output [ 7: 0] q; input [ 7: 0] data; input [ 20: 0] rdaddress; input rdclken; input [ 20: 0] wraddress; input wrclock; input wren; reg [ 7: 0] mem_array [2097151: 0]; wire [ 7: 0] q; reg [ 20: 0] read_address; //synthesis translate_off //////////////// SIMULATION-ONLY CONTENTS always @(rdaddress) begin if (1) read_address <= rdaddress; end // Data read is asynchronous. assign q = mem_array[read_address]; initial $readmemh("cfi_flash_0.dat", mem_array); always @(posedge wrclock) begin // Write data if (wren) mem_array[wraddress] <= data; ///memory array end //////////////// END SIMULATION-ONLY CONTENTS //synthesis translate_on //synthesis read_comments_as_HDL on // always @(rdaddress) // begin // if (1) // read_address <= rdaddress; // end // // // lpm_ram_dp lpm_ram_dp_component // ( // .data (data), // .q (q), // .rdaddress (read_address), // .rdclken (rdclken), // .wraddress (wraddress), // .wrclock (wrclock), // .wren (wren) // ); // // defparam lpm_ram_dp_component.lpm_file = "cfi_flash_0.mif", // lpm_ram_dp_component.lpm_hint = "USE_EAB=ON", // lpm_ram_dp_component.lpm_indata = "REGISTERED", // lpm_ram_dp_component.lpm_outdata = "UNREGISTERED", // lpm_ram_dp_component.lpm_rdaddress_control = "UNREGISTERED", // lpm_ram_dp_component.lpm_width = 8, // lpm_ram_dp_component.lpm_widthad = 21, // lpm_ram_dp_component.lpm_wraddress_control = "REGISTERED", // lpm_ram_dp_component.suppress_memory_conversion_warnings = "ON"; // //synthesis read_comments_as_HDL off endmodule // turn off superfluous verilog processor warnings // altera message_level Level1 // altera message_off 10034 10035 10036 10037 10230 10240 10030 //main module module flash_MAIN ( // inputs: address, read_n, select_n, write_n, // outputs: data ) ; inout [ 7: 0] data; input [ 20: 0] address; //address is input which should be output for controller input read_n; input select_n; input write_n; wire [ 7: 0] data; wire [ 7: 0] data_0; wire [ 7: 0] logic_vector_gasket; wire [ 7: 0] q_0; //s1, which is an e_ptf_slave //synthesis translate_off //////////////// SIMULATION-ONLY CONTENTS assign logic_vector_gasket = data; assign data_0 = logic_vector_gasket[7 : 0]; //cfi_flash_0_lane0, which is an e_ram cfi_flash_0_lane0_module cfi_flash_0_lane0 ( .data (data_0), .q (q_0), .rdaddress (address), .rdclken (1'b1), .wraddress (address), .wrclock (write_n), .wren (~select_n) ); assign data = (~select_n & ~read_n)? q_0: {8{1'bz}}; //////////////// END SIMULATION-ONLY CONTENTS //synthesis translate_on endmodule - Altera_Forum
Thank you for the hint, flash_controller.v actually seems to contain the logic to control flash writes, utilizing a state machine and a timer. It's of course nearly undocumented as any Terasic source, but a starting point anyway. I regard it useful, if I ever may design a flash controller. The code can be found below DE2_demonstrations\DE2_USB_API\HW\Multi_Flash
Thank You FvM. It worked I am able to read and write using that Flash COntroller.:)
I have another question, DO you have any idea what is maximum speed for writing on to flash? I have tried different speeds 50MHz to 10Khz. I n that 10KHz -125KHz clock works good but if I increase the clock to 250KHz then it skips some address locations. Those locations remains FF only. Please let me know if you have idea baout Flash Writing speed. Thank You.
