17 years agoCyclon III starter Kit, flash device
hello, i have a problem to program the flash device of the cyclon III starter Kit. I use Quartus 7.2. Up to kno i program the *.sof file and the program works. Now i want to start the progra...
17 years agoThe can't recognize silicon id for device i isn't related to JTAG but to the flash loader IP. It's also using JTAG, but if the FPGA is recognized at the JTAG chain, it's probably not a JTAG problem. A possible reason is, that the present FPGA configuration doesn't contain the PFL IP or is conflicting with flash programmer operation somehow. In this case, the factory default parallel flash loader should be loaded instead. It can be found in the \quartus\common\devinfo\programmer directory.
