17 years agoCyclon III starter Kit, flash device
hello, i have a problem to program the flash device of the cyclon III starter Kit. I use Quartus 7.2. Up to kno i program the *.sof file and the program works. Now i want to start the progra...
17 years agoLooks like the USB Blaster is not able to get the device ID from the JTAG port. Try disconnecting everything and re-connect (probably after a restart) and see if you are able to auto detect the JTAG chain in the Quartus II programmer. If you are able to detect the FPGA in the auto detection, you should be able to program the FPGA.
