18 years agoCreating a clock pulse
I am trying to create 7 different clock pulses that will go from high to low at a certain time. Can anyone help me? This is what I have so far: library IEEE; use IEEE.std_logic_1164.all; ...
18 years agoThe input signal will come from a keypad or other input device that we will attach to the microcontroller. From there, the switch will be turned on for a certain amount of time and then switched back to zero. These pulses will then go out of the microcontroller to AND gates to control Solid state relays which will then open voltage-controlled solenoid valves. Would this be possible to do with J-K flip flops or is there another way we can easily do this? Thank you again for all of your help.
