Converting .sof to .flash in Nios II Command Shell
I've got an Arria 10 GX FPGA Development Board (DK-DEV-10AX115S-A) and am trying to convert a .sof file to a .flash file for use with the board. I'm using Quartus Prime Standard 23.1. I'm referring ...
Ya same according to SStrell comment, you will need to be in the directory of where your .sof file has been generated then only run the sof2flash command.
