convert avalon bus to AXI4-Lite
Your first screenshot is blocking signal names in Signal Tap and your third screenshot is blocking the addresses that are to be accessed in the new component (guessing it's 0x80000 from the code), so it's difficult to correlate what you are showing in hardware with the code. What address are these data values being written to? That doesn't appear in the code either.
Is FPGA_SCAN_WRITE supposed to be the write enable signal so why would it appear on the data bus?
If you're coding Avalon, address and data should be put on the bus simultaneously on the separate signals (address and writedata). These would then translate on the separate channels on the AXI side on different signals: write address channel (AWADDR), write channel (WDATA), write response channel (BRESP).
Is your design meeting timing?
More explanation of your code and seeing actual hardware addresses and setup would help.
Link to the Avalon spec as well: https://www.intel.com/content/www/us/en/docs/programmable/683091/22-3/memory-mapped-interfaces.html
Please refer to my pseudo-code as follows.
I am 100% sure the test C code, verilog code, and everything things are correct.
The axi4lite Verilog code in my project has previously used and verified in my old project, so I confirm Verilog code of Axi4Lite is correct.
My main uncertainty, doubts and concerns are:
1) whether I connect/configured avalon to axi4lite correctly.
2) I left shift 2bits of the bias address of those registers in C code. I don't know whether is correct or not.
Please help to confirm my upper doubts based on the pictures and pseudo-code I pasted.
In Verilog code, I defined registers:
`define SCAN_WADDR_N 6'h18 // 60 <-- 0x18 Left shift 2 bits
`define SCAN_WDATA_N 6'h19 // 64
`define SCAN_WRITE_N 6'h1A // 68
In C code, I access those registers by the following address:
#define FPGA_SCAN_WADDR (FPGA_REGS_ADDR + (0x18<<2))
#define FPGA_SCAN_WDATA (FPGA_REGS_ADDR + (0x19<<2))
#define FPGA_SCAN_WRITE (FPGA_REGS_ADDR + (0x1A<<2))
In system.h in BSP:
#define ALT_MODULE_CLASS_BF5V_0 BF5V
#define BF5V_0_BASE 0x80000 // this address is the same as that in Platform Designer
#define BF5V_0_IRQ -1
#define BF5V_0_IRQ_INTERRUPT_CONTROLLER_ID -1
#define BF5V_0_NAME "/dev/BF5V_0"
#define BF5V_0_SPAN 256
#define BF5V_0_TYPE "BF5V"
The test C code is:
int main()
while(1)
FPGA_Write(FPGA_SCAN_WADDR, 0x55AA); // write address
FPGA_Write(FPGA_SCAN_WDATA, 0x33); // write data
FPGA_Write(FPGA_SCAN_WRITE, 0x0001); // write enable signal
FPGA_Write(FPGA_SCAN_WRITE, 0x0000); // clear write enable signal
return 1;
- sstrell1 year ago
You have to be coding for Avalon, not AXI for a Nios processor. Have you gone through the software developers handbook for Nios? https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/eol.html
What address is FPGA_REGS_ADDR? Shouldn't this be BF5V_0_BASE?
