Constraining output clocks properly in *.SDC
- 5 years ago
Okay that makes sense. For now I'm using an eval board and this clock is not on a designated clock pin. When I compile it gives me a warning under Fmax "limit due to minimum port rate restriction" that it can only achieve up to 125MHz and we are running above that. In the final version, this pin will be routed on an actual clock pin.
All clocks need to be constrained, no matter what resources are used. Your constraint for the output clock is correct. Add this
set_false_path -to [get_ports {SDRAM_OUT}]
so that the output clock path is not analyzed as a data path.
Hi again,
I just realized I had made a type (SDRAM_OUT was supposed to also be named CLK_OUT). Anyway, I'm wondering why I'm still getting a min pulse width violation? I was wondering if you had any idea?
Thanks again,
Erica
- sstrell5 years ago
You'd need to check to see if the target device's PLL you are using is capable of whatever clock speed you are trying to generate. Perhaps it's too fast, causing the violation.
- Erica5 years ago
