JArti2's avatar
JArti2
6 years ago
Configuration Flash Memory For Cyclone IV E - Military Grade?
I'm designing a military application using a Cyclone IV E device (EP4CE55F23A7N - automotive grade), but can't seem to locate an automotive grade configuration flash memory chip. I need one that goes up to at least 125 degrees C, and I want to us Active Serial AS Mode. Do you have, or can you please recommend, a part for the task? This is a requirement by the Military so any help, part number, etc, that you can provide will be greatly appreciated!
Thanks!
  • JArti2's avatar
    JArti2
    This is the way I did it with Intel flash memory, and I want to do something similar with Micron flash (please see attached image).
    I use an AS module in the FPGA, and program the flash through that. I then convert my programming files to .jic, and program the flash.
  • JohnT_Altera's avatar
    JohnT_Altera
    For the connection in blue it s as below.
    RESET# - Weak-pull high.
    HOLD# - Weak-pull hig.
    W# - Weak-pull high
    DNU - floating
    RFU - floating
    NC - floating
  • JArti2's avatar
    JArti2
    Hi JohnT,
    That is exactly what I needed!
    Thank you for that!
    I have one other thing to ask, and that is what to do with all the RFU_1 - RFU_14 (please see the attached image)
    Also, does everything look right in the schematic I attached, mainly the connections to the FPGA?
    Thanks again for all your help!
    JohnT_Altera
    The connection to the FPGA looks fine for me. I would recommend you to connect the RESET# of the flash to weak-pull up to avoid it entering reset state.
  • JArti2's avatar
    JArti2
    Thanks JohnT, truly appreciate all your help here.
    Got, I will add the weak pull-ups on the flash.
    So I have the correct flash pins matched up to the correct pins of the fpga?
  • JArti2's avatar
    JArti2
    Can you please look at the attached schematic and let me know if this looks complete?
