jelly
2 years agoconf_done LED blinks once
Hi, I'm a FPGA newbie with a DE10-nano board and have a problem with it. I use the USB blaster. When I supply power on my board, 3.3V Power LED, conf_done LED go HIGH, and USER LED blinks....
- 2 years ago
Do you have an SD card installed? If so, the HPS is probably booting and then reconfiguring the FPGA back to its default design.
BXia
2 years agoWhat Quartus are you using to compile the code? What kind of .sof file did it generate, like xxx_time_limited.sof?
