jelly
2 years agoconf_done LED blinks once
Hi, I'm a FPGA newbie with a DE10-nano board and have a problem with it. I use the USB blaster. When I supply power on my board, 3.3V Power LED, conf_done LED go HIGH, and USER LED blinks....
- 2 years ago
Do you have an SD card installed? If so, the HPS is probably booting and then reconfiguring the FPGA back to its default design.
sstrell
2 years agoDo you have an SD card installed? If so, the HPS is probably booting and then reconfiguring the FPGA back to its default design.
- jelly2 years ago
(I didn't intend to click the accept button! My problem isn't solved.)
Yes I already have inserted the SD card in my board. ;(
Sometimes the loaded data is gone and sometimes it remains.
What is the problem.. ~~
