17 years agocommunication with altera fpga starter kit.
hi, i have had this board lying around and i want to try something with it which does more than produces a pattern on the 4 LEDs. there are these weird HSMC connectors which i cant see an rs232 bo...
17 years ago --- Quote Start --- is there any way i can use the JTAG connection to emulate a serial port so i can send/recieve bytes from hyperterminal. --- Quote End --- It can be if you can take care of writing driver code yourself. I have deliberated on this idea sometime back. Here is a thread on a discussion on using JTAG as a serial port: http://forum.niosforum.com/forum/index.php?showtopic=4224&st=0&p=16504&#entry16504 --- Quote Start --- Is there some kind of megafunction associated with these that acts like a uart? --- Quote End --- Yes there are RS-232 cores available: http://www.altera.com/education/univ/materials/ip-cores/unv-ip-cores.html
