19 years agoClock Issue For A Vga Controller
Hi, I'm trying to design an 640x480 VGA controller for which the simulation seems alright. However, when I program the CYCLONE || FPGA STARTER KIT, nothing appears on the screen. I suspec...
19 years agohi
Are you sure the code below doesnt have a problemm!! I am not suree about the real problem you are facing.. just a look at your code made me to comment... entity vga_ctrl is port( CLOCK_50 : out std_logic; -- Symbolic name for 50Mhz onboard 50 Mhz -- clock clock_in : inout std_logic; -- VGA controller clock input; ); end vga_ctrl; architecture behavior of vga_ctrl is begin clock_in <= CLOCK_50; -- Logically, this should work; but still, it -- does'nt. end behavior; You have declared CLOCK_50 as OUT and you are tryingg to assign it to clock_in.........
