19 years agoClock Issue For A Vga Controller
Hi, I'm trying to design an 640x480 VGA controller for which the simulation seems alright. However, when I program the CYCLONE || FPGA STARTER KIT, nothing appears on the screen. I suspec...
19 years agoThanks Ben for answering.
The CYCLONE || Starter Kit has on board 3 crystals, 24MHz, 27MHz, and 50MHz. Using VHDL code, I know how to use the 7_SEGMENTS, KEYS, LEDS, etc..., but I'm having problems to use one of the crystal oscillators listed above using the same technics used to access the other peripheral onboards. For example, if I want to write the key values to the LEDs, using the code below will do : entity key_To_Led is port( key : in std_logic_vector(9 downto 0); -- key and ledr are the symbolic -- names for the ledr : out std_logic_vector(9 downto 0); -- 9 keys and 9 red leds on my -- kit. end key_To_Led; architecture behavior of key_To_Led is begin ledr <= key_To_Led; end behavior; Now, if if for example I want to access the 50 Mhz onboard clock generator, I would have probably to use the same type of coding as : entity vga_ctrl is port( CLOCK_50 : out std_logic; -- Symbolic name for 50Mhz onboard 50 Mhz -- clock clock_in : inout std_logic; -- VGA controller clock input; ); end vga_ctrl; architecture behavior of vga_ctrl is begin clock_in <= CLOCK_50; -- Logically, this should work; but still, it -- does'nt. end behavior; Again, unless there's something wrong with my code in general, I do not know what else to do to access any of the onboard clock generators. I'll appreciate any idea that would help. Regards,
