ymiler
Contributor
2 years agoclock gated conversion
Hello, I'm running Quartus 22.3 building for an S10 FPGA. Since my FPGA is prototype, the project includes several clock gated to solve it I added the following command to the QSF : set_glob...
Adrien_Lacroix
1 year agoHello,
I am facing the same issue trying to synthetize my design into a Stratix 10 (1SG280H).
I am using this FPGA for ASIC prototyping and I also have several (and cascaded) gated clocks.
Do you have a solution to correctly convert those gated clock into clock enable ?
I have tried so far:
- using "set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION ON". It does not work as several clocks are not correctly converted.
- using a module "stratix10_clk_ctrl" but it does not work as it seems that this module does not accept to receive a gated clock in input (so it does not work for cascaded gated clock)
I am using Quartus Prime Pro 24.2.0
Thank you,
Adrien
- ymiler1 year ago
Contributor
Hi Adrien
I still haven't received a solution to my issue.
However, I have opened a case on the Altera support website.
As far as I know, they are working on finding a solution in their next release.
