17 years agoclk input 50 MHz to pinE13 CycloneIII dev kit
Hi all learned members of the forum, I am writing a Verilog code to drive the 7-segment user display using clock signal to count 0 to 3 while selecting inputs from mux to selectively drive each...
17 years ago --- Quote Start --- The reference manual says signal propagates to pin E13 of the FPGA. --- Quote End --- I see, that this is written in the manual. Actually E13 is a VCCIO8 pin. You may ask Altera for a correct version of the reference manual. P.S.: According to the schematic, CLKIN_50 is to PIN_AH15. There's also a cycloneIII_3c120_dev_quartus_pinouts example, that contains most relevant pinouts.
