Clarification on Features in MAX10 Compact Devices
Hi RonSegev,
Please find the answers to your questions below:
1. On-Chip Flash Intel FPGA IP Core: Is this IP core available in compact MAX10 devices as it is in the non-compact versions? Specifically, will I be able to read, erase, and program both the User Flash Memory (UFM) and Configuration Flash Memory (CFM) using this IP? Additionally, does it support non-default flash initialization?
<Answer> You can check more detailed information at On-Chip Flash Core Documentation. Refer to the support table for further details.
2. Design Security Features: Are design security features supported in compact MAX10 devices?
<Answer> Refer to Section 2.2.2: Configuration Design Security in the Configuration Design Security Documentation.
3. Additional Feature Activation: Is there a way to enable features like remote system upgrade and memory initialization in the compact MAX10 devices?
<Answer> Refer to Section 2.2.1: Remote System Upgrade in the Configuration Design Security Documentation.
Let me know if you need further clarification.
Fakhrul
