BWU15's avatar
BWU15
7 years ago
Cisco asked us that collect the part marking on FPGA components and ask the respective vendors if there is any common thing like all of them are of certain silicon type/sped grade”??
As of today, there’re 44pcs failed with” Emanframes” failure code ,suspect related to FPGA 16-100521-01/5AGXMA7G4F31I5NAB
DC and lot code for the 44pcs as following:
DateCode Lot Code Qty
1837 S834AFFR 4
1837 S834AFFS 5
1837 S834AFFT 23
1837 S834AFFU 5
1837 S834AFFW 5
1837 S834AFFY 1
1837 S836AFFS 1
Aattachment is the FPGA pictures
  • Hi Bruce, First of all, i apologies for late response to your thread. Unfortunately, I am not able to view the FPGA pictures from your attachment. Please could you re-upload the picture. To know the speed grade of 5AGXMA7G4F31I5NAB, you can refer to Arria V device overview, Figure 1 which shows it is speed grade-5. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_51001.pdf In order to know if there any common thing in term of the die revision, would you please provide the full device date code which is 11 alphanumeric as stated from the following link: https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/decoder.html Next, please could you elaborate further of the 'Emanframes' mode? • What kind of function can’t work normally? • Did you encounter any open/short failure? • Any abnormality on the power rail performance? • Any suspected failure pins? Did any of the defective units above send to failure analysis? Thank you Regards, Chia Ling
  • Hi Bruce,
    Just dropping by to check if you have any update on above. Please be noted that a respective team will continue follow up with you in private message.
    Thank you
    Chia Ling
  • Hi Bruce, Do you have any update on this request? Thank you Regards, Chia Ling
  • BWU15's avatar
    BWU15
    ​Yes, we want to send 5pcs defects with such failure code to your site ,so could you tell us the process to FA ?what information can we tell you ,and what is the shipping information can you pls help to release to us asap ?Thanks!
    • ChiaLing_T_Intel's avatar
      ChiaLing_T_Intel
      Hi Bruce,
      You will receive a separate email from our respective FA team. Please work with the team for shipping information.
      Thank you
      Chia Ling
  • BWU15's avatar
    BWU15
    ​Can you pls shipping back the 5 components to us ? we need to re-verify !
    Flextronics Manufacturing (Zhuhai) Company Limited
    伟创力制造(珠海)有限公司
    Xin Qing Science & Industrial Park , Jing An,
    Doumen , Zhuhai , P. R. China.
    珠海市斗门区新青科技工业园B11
    TEL:+86 (0756) 5183945/+86 150-1490-0119
    ATTN: Tide zhang
    zip: 519000
      ChiaLing_T_Intel
      Hi Bruce,
      We will have the ERMA team to arrange the shipment back to you.
      Thank you
      Chia Ling
  • BWU15's avatar
    BWU15
    ​hi Altera guys,
    Can you tell us where is the 5componenents located ,can you share us the address where is 5 component located? Thanks!
  • Zawani_M_Intel's avatar
    Zawani_M_Intel
    I believe you have received your devices. If you have any concern, please do let me know.
    Have a great day!
    Wani
