18 years agochange logic cell to memory M4K in cylocne 2
How I can say to Quartus 2 (7.2), to replace logic cells to memory blocks M4K in Cyclone 2 device? I would like to implement following array with memory M4K and not LC type CoefArrType is arra...
18 years agoI wonder how you achieved to make Quartus use LC for a the signal array? Most likely you have multiple accesses to the signal in your code or are assigning the address expression outside a clock synchronous process. You should consider the limitations of internal RAM hardware.
