8 years ago
Can't SSH to Arria 10 Dev Board
I just received our Arria 10 Dev Boards and I'm running through the quick start guide. I can get to the web interface and blink some lights and change the LCD message. I tried to SSH to it and the following happened:
$ ssh [email protected] authenticity of host '192.168.0.21 (192.168.0.21)' can't be established.
ECDSA key fingerprint is SHA256:6Roa+AUDD3RyzVleUJS04lWWt7tdVvD1LrZBkHTwADE.
Are you sure you want to continue connecting (yes/no)? y
Please type 'yes' or 'no': yes
Warning: Permanently added '192.168.0.21' (ECDSA) to the list of known hosts.
Connection to 192.168.0.21 closed by remote host.
Connection to 192.168.0.21 closed.
All subsequent attempts end the same:
Any idea what's happening?
    Try to add some -v's to get more verbose debug output:
    ssh -vvv -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null [email protected]
    You can also see if you get any response from the server using telnet or netcat:
    nc 192.168.0.21 22
    You should see something like:
    SSH-2.0-OpenSSH_7.5p1-hpn14v12
    depending upon the ssh version you hav running on your board.
    • PJais1's avatar
      PJais1
      Hello , i am facing same error.On entering the command :
      OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014
      debug1: Reading configuration data /etc/ssh/ssh_config
      debug1: /etc/ssh/ssh_config line 19: Applying options for *
      debug2: ssh_connect: needpriv 0
      debug1: Connecting to 192.168.1.10 [192.168.1.10] port 22.
      debug1: Connection established.
      debug3: Incorrect RSA1 identifier
      debug3: Could not load "/home/bmit/.ssh/id_rsa" as a RSA1 public key
      debug1: identity file /home/bmit/.ssh/id_rsa type 1
      debug1: identity file /home/bmit/.ssh/id_rsa-cert type -1
      debug3: Could not load "/home/bmit/.ssh/id_dsa" as a RSA1 public key
      debug1: identity file /home/bmit/.ssh/id_dsa type 2
      debug1: identity file /home/bmit/.ssh/id_dsa-cert type -1
      debug3: Could not load "/home/bmit/.ssh/id_ecdsa" as a RSA1 public key
      debug1: identity file /home/bmit/.ssh/id_ecdsa type 3
      debug1: identity file /home/bmit/.ssh/id_ecdsa-cert type -1
      debug1: identity file /home/bmit/.ssh/id_ed25519 type -1
      debug1: identity file /home/bmit/.ssh/id_ed25519-cert type -1
      debug1: Enabling compatibility mode for protocol 2.0
      debug1: Local version string SSH-2.0-OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.13
      debug1: Remote protocol version 2.0, remote software version OpenSSH_7.8
      debug1: match: OpenSSH_7.8 pat OpenSSH* compat 0x04000000
      debug2: fd 3 setting O_NONBLOCK
      debug3: load_hostkeys: loading entries for host "192.168.1.10" from file "/dev/null"
      debug3: load_hostkeys: loaded 0 keys
      debug1: SSH2_MSG_KEXINIT sent
      and it hangs after this command.
      Also by entering : nc 192.168.1.10 22 , the terminal shows following output.
      SSH-2.0-OpenSSH_7.8
      Could you help with above query?
      Priya
