15 years agoCan't scan JTAG chain
Hi all, I had posted this issue previously, but nobody replied. I even created a webcase, but I am not getting any response from Altera. Anyway, I am trying my luck again. I have a Nios dev k...
15 years agoHello FvM & Daixiwen,
Thank you for the response. The byte blaster is not working on another board as well. This board contains a CPLD in JTAG mode. I was thinking that if AS programming is going through fine, then there should not be any problem with JTAG programming as well. I will try to change the blaster cable and then update the results. regards, rajesh
