14 years agoCan't load design for PCIe tab in BTS with transceiver starter kit
Just got a Cyclone IV Transceiver Starter Kit, but can't get to the point I can access the PCIe tab in the Board Test System (BTS). Version 11.1.0 of BTS doesn't display a "Configure" menu, so ...
14 years agoBefore you can run the PCIe test;
1) You need it plugged into a PCIe motherboard slot. 2) You need the design configured *before* the BIOS enumerates the PCI/PCIe bus. That last step can be a little tricky. There's couple of ways to do it; 1) Configure the board for passive serial configuration and load the PCIe BTS image in the flash so that the board is configured at power-on. This is the method you need to use if you want to turn the power-on to your PC and have the Cyclone board detected at each power-on. 2) Turn on your PC with the Cyclone board plugged in. Use Quartus to download the PCIe BTS image (it'll be in one of the install directories as a .sof file). Soft-reboot your machine by doing a restart (not a power-down). When your PC reboots, the BIOS will detect the Cyclone board as a PCIe device. Once Windows starts, you can run BTS and it should detect the configuration. Yes, Altera's documentation leaves a little to be desired ... I believe the above should work. If it doesn't let me know, and I'll try with the board I have. Cheers, Dave
